BETTER BUILT BET64010144 16 X 12 X 60 IN. TOP MOUNT TOOL BOX SINGLE DOOR
Features- This top mount tool box sits on top of the truck bed rails saving valuable storage space inside the truck
- Top mount boxes are easy to install on the bed rail of any truck using the included legs
- The stainless steel t-handle latches provide solid maximum security while using a minimum of space
- Door cables prevent over extension of the door
Specifications- Dimension: 16 H x 12 W x 60 L
- Weight: 36 lbs
Price: 776.71
