BETTER BUILT BET64210122 16 X 12 X 72 IN. TOP MOUNT BLACK STEEL TRUCK TOOL BOX DOUBLE DOOR
Features- This top mount tool box sits on top of the truck bed rails saving valuable storage space inside the truck
- Top mount boxes are easy to install on the bed rail of any truck using the included legs
- The stainless steel t-handle latches provide solid maximum security while using a minimum of space
- Door cables prevent over extension of the door
Specifications- Finish: Black
- Material: Steel
- Dimension: 16 H x 12 W x 72 L
- Weight: 91 lbs
Price: 905.38
