DELTA 480000 FUEL TANK L SHAPE 105 GALLON
Delta tanks feature 14 Gauge construction for Long-Term durability. Internal baffles reinforce the High-Strength design and control the flow of the contents when moving. All trucks are pressure tested for leaks.
Features- Internal Baffles Add Extra Strength And Control The Flow Of The Contents When Moving
- 2 in. NPT Reinforced Bungs Allow Convenient Use From Either Side. Filter System Recommend
- Built-In Lifting Rings To Assist With Lifting And Moving An Empty Tank
- Lockable Filter Cap And Coupler Prevent Excessive Pressure Build-Up
- Heavy-Duty Brackets To Secure The Tank To The Truck Bed. All Brackets Must Be Bolted To The Truck Bed
- Type of Liquid - Non-Flammable Liquids And Diesel Fuel
- Shape - L-Shape
- Volume - 105 Gallons
- Finish - Smooth
- Color - White
Price: 953.06
